Previous in Forum: project research topic.   Next in Forum: calculators for mechanical
15 comments
Single-Turn Potentiometers vs. Multi-Turn Potentiometers
02/12/2009 6:31 PM
What is exactly the difference between single and multi turn potentiometers? What is the difference between a 3 turn and say a 10 turn pot, application wise?
thanks!
Re: pot
02/12/2009 6:38 PM
more turns.
Ferinstance, take a 1000 Ω pot. With a single turn pot as you turn it from full CCW to full CW the resistance at the wiper pin goes from 0 to 1000. For a 3 turn pot, it takes three full rotations of the knop to go from 0 to 1000. For a 10 turn pot it takes ten turns, etc.
The application difference is the amount of resolution you need from the pot. If 10% resolution is enough, use a single turn pot. If you need to adjust the resistance to within, say, 1%, you need a 10 ten turn pot, etc.
Re: pot
02/12/2009 6:42 PM
Assuming you're a mechanical type, think of it in terms of gears. A 1:1 ratio turns your widget one time with one rotation. A 10:1 gear ratio takes 10 turns to move your widget through one rotation, and you get much finer control of how precisely the widget turns.
Good Answers: 68
Re: Single-Turn Potentiometers vs. Multi-Turn Potentiometers
02/13/2009 11:07 PM
Hello vscid,
As bhankiii said, the multi turn have very much finer adjustment. In audio for instance, if you have several thousand watts of power, it could break some instruments and deafen anyone too near, if you used a single turn, as you would go from zero to B*O*O*M instantly. It is much easier to finely adjust a sound system or anything you may need a potentiometer to change the potential in/out phase, if you need delicate adjustments, with a multi turn potentiometers.
Take care...............Hope you find this helpful......................
02/14/2009 6:57 AM
What Bhankiii has told in his GA, is right. But I would like to add few more details:
Normally single turn potentiometer turns by 20 deg only. Thus, the resolution you get is 1000/270 ohms (just as an example... this doesn't mean that you turn the potentiometer in single deg steps,)
But multiturn you get rotation of almost 360 X no. of turns. 10 turn potetiometer you get almost 3600 deg rotation. Besides, you can attach mechanical counter to multiturn potetiometer, so that just by viewing the counter reading, you can set the potentiometer to reasonably good set point.
In single turn potetiometer, counter can not be fitted, and you have to use angle dial, which is not good enough to set the value to reasonably accurate set point, as even the manual errors will be there due to paralax
Good Answers: 68
02/14/2009 8:44 AM
Hello gsuhas:
I was not aware you could get potentiometers which tuned than many times?.Some new I have learned.
How are you gsuhas? I have not spoken for some time.
Take care my friend..................................
02/14/2009 11:24 AM
Hello Friend Babybear
This is what I mean. This counter, (you must be knowing), can be fitted on the multiturn potentiometer and we can see full turns in main window, and fraction of turn on rotory dial.. with least count of 1/100 turn.
Thus effectively, we get resolution of (for sample example of 1000 K potetiometer) 1 ohm.
I did not get what you mean by tuning.
I am fine. You? I always like your caring end "Take Care"
Good Answers: 68
02/14/2009 11:47 AM
Hello gsuhas:,
I know these OK. I thought you were talking of a digital readout?
Very useful for presets.
Take care.............................
02/14/2009 1:03 PM
For simple understanding - Say you are adjusting an input between 0 to 10V.
A pot with single turn will give a possibility of 0 to 10V in single turn but a 10 turn pot will give the same in 10 turns. So you get a finer control with a 10T pot. It is as simple as that.
Good Answers: 38
02/15/2009 7:11 PM
well the Others allready answered correctly but the name itself should have been a strong hint
Good Answers: 68
02/15/2009 11:50 PM
Hello Epke,
How are you? I like your sense of humour!
Take care........,
Good Answers: 38
02/16/2009 12:32 AM
Humour? don't know the meaning of the word
Anyway where mostly in Europe?
Good Answers: 12
02/16/2009 4:02 AM
Just a comment... If I were building a 10 turn pot, I would probably use a CERMET pot as the resistive element. Can you imagine a wire wound pot where the resistance would go Boing! Boing! as you passed the wiper from one wire to the next? Quantizing error!
So basically, a 10 turn pot is a single turn pot (not wire wound) whose feed is mechanically geared down to allow more precision.
Bill
South Africa - Member - Member Shonver
02/16/2009 5:54 AM
Multi-turn wire-wound pots are indeed available. I believe that the wiper does not only contact one turn at a time, but is always in contact with at least 1 turn.
Also, FYI (OP), a single-turn pot turns only 270 degrees, mostly.
DON'T PANIC
02/16/2009 6:34 AM
Sciesis
You are misunderstanding. No gearing is there for multiturn. It is a spiral of 3600 deg, as against only 270 deg in case of single turn.
Besides, wiper is touching more than 1 turn at a time. It doesn't jump wire to wire. Besides, it may be conductive plastic or hybrid, instead of wires only, to get infinite resolution.
Please go through
http://www.bourns.com/data/global/pdfs/OnlinePotentiometerHandbook.pdf
It is everything about potentiometers.
02/17/2009 7:26 PM
There is one other big difference that no one has mentioned. The 1/2 watt 270 degree pots are only good for about 60 adjustments and they they start to lose integrity. I have never has a multiturn potentiometer wear out so quickly.
Register to Reply 15 comments
Anonymous Poster (1); babybear (4); bhankiii (2); Epke (2); gsuhas (3); Sciesis2 (1); Shonver (1); silvCrow (1)
