Hi all,
I am installing a tank gauging system on a pipeline terminal that is on SCADA.
My tank gauging system measures, level, temperature, pressure and density.
From these values volume is calculated. I want to interface, the gauging software to SCADA, we had interfaced the system in an earlier terminal but the information being received on SCADA was not correct e.g 4m would be seen as 40m. Could you please highlight the main issues i should look into to as to communicate effectively.
vincent
