we want to make a hover craft for this we have taken tube of a tractor.
this tube which will develop the required buoyance force in order to lift the
weight in the water if our blower fails to run.
On this tube we placed a ply wood with a centre hole.
the centre hole is required to place blower.
now our problem is to select a blower with a c.f.m & velocity that will lift
the entire equipment
the data we have is
pay load:60kgs,
height to be lifted:0.5inch,
inner diameter of the tube:60cm,
mean diameter of the tube:98cm,
NOW ACCORDING TO OUR CALCULATIONS:
c.f.m=(cross section area through which air flows)*velocity of air flow
c.f.m=(perimeter of the tube * height to be lifted)*velocity
c.f.m=((2*(pi)*r)*h)*v
r= mean radius of the tube
h=0.5inch
v=?
can we get value of v from bernoullies equation
i.e..,
if so please tell us the procedure to calculate along with the values
