Previous in Forum: Perhaps ordinary (primary) batteries can be recharged. I was able to .   Next in Forum: connection of parallel circuit on a breadboard
how to desing Earth faulty Relay??
02/15/2009 2:46 AM
i have core balance CT
so pass three phase of the motor in this CT when any phase is imbalance or earth faulty in any phase or both or three phase so current direction is one state
so current will flow in CT out put
CT is 100/5 415v 50hz
so whts is the out put voltage/current and whts the rating of the realy and current limiting circuit how to desing this thing if any have idea so plz suggest with calculation.
Paresh Joshi
Re: how to desing Earth faulty Relay??
02/16/2009 4:02 AM
um.... what?
No set of mutually inconsistent observations can exist for which some human intellect cannot conceive a coherent explanation, however complicated
Good Answers: 103
02/16/2009 5:11 AM
Are we talking about CT as we know ?
What is the expected voltage at out put ? I always thought it should be zero.
The current limiting circuit - on CT secondary ? never heard the term.
Relay rating and settings depends on the load.
Please assign the job to some professional or else not only the motor will be un protected but also it may be dangerous if you put current limit on CT secondary.
Good Answers: 80
02/16/2009 9:28 AM
The voltage coming out of the CT will be the imbalanced of current divided by the ratio (100/5 = 20) times the burden resistor you will be using.
Normally, you want this voltage to stay below a few volts to avoid core saturation.
In this application, the CT is sized for only a fraction of the supply current to have enough sensitivity.
E.G. A 100A CT would likely be used on a 1000A supply or more. If the imbalance is 5% (50A), the current in the burden will be 50A/20 = 2.5A. Using a common 0.47Ω 25W resistor, the voltage will be ~1.2V.
Other values of resistors could be used depending on the VA capacity of your CT.
03/11/2009 2:00 AM
Thanks for all the reply
but can any one give the realy rating which one i use it for that
i have a 24V ac/dc realy
its is advisable that it will be connected or not ? or any possibilities of burning the realy coil when i connect in CT secondary????????
Register to Reply 4 comments
benbenben (1); marcot (1); pareshh_joshi (1); sb (1)
