Previous in Forum: Parallel Port Access - Help Needed   Next in Forum: Converting Fax or PDF Scan to AutoCAD Format
19 comments
Convert UPPER CASE to lower case
02/15/2009 9:06 AM
Sometimes, when I've just finished yelling at someone, I forget to hit the caps lock button and return to lower case.
Aside from starting over, is their a way to Convert UPPER CASE to lower case?
I have 2000, XP and Vista.
Thanks,
LL
8
The Engineer
Good Answers: 129
Re: Convert UPPER CASE to lower case
02/15/2009 9:30 AM
There's this nice feature in Microsoft Word that allows you to change the case of a large section of text. It offers choices such as changing the case to Sentence case, lower case, UPPER CASE, Title Case, and tOGGLE cASE (I have no idea when to use toggle case).
THE POINT IS THAT IF YOU HAVE FORGOTTEN TO TURN OFF YOUR CAPS LOCK AND YOU WANT TO FIX THE CASE OF YOUR TEXT WITHOUT DOING IT OVER, YOU CAN SIMPLY COPY THE TEXT YOU WANT TO FIX, PASTE IT INTO MICROSOFT WORD, HIGHLIGHT IT, THEN GO TO FORMAT AT THE TOP MENU, SELECT THE CHANGE CASE OPTION THAT YOU WANT, COPY THE ALTERED TEXT FROM MSWORD BACK INTO THE CR4 TEXT BOX AND ITS FIXED.
See converted text below.
The point is that if you have forgotten to turn off your caps lock and you want to fix the case of your text without doing it over, you can simply copy the text you want to fix, paste it into microsoft word, highlight it, then go to format at the top menu, select the change case option that you want, copy the altered text from msword back into the cr4 text box and its fixed.
I selected "Sentence Case" for my choice to alter the text above. You'll have to go back and fix proper names and acronyms but the rest will be correct. Nice trick right? Here some images to show you where to go in Microsoft Word.
After you click on Change Case you get the following menu:
Hope that helps. I'd tell you not to yell, but that would just make me a hypocrite.
Roger
Register to Reply Good Answer (Score 8)
02/15/2009 9:39 AM
Thanks for the info. Roger. I'll let you know if I figure the toggle out.
Today was the first time I've ever yelled, at least on CR4.
Some jerk wanted to know how to connect his laptop while driving....................
Go figure.
LL
The Engineer
Good Answers: 129
02/15/2009 11:42 AM
Yes, I saw that, as if drivers weren't distracted enough by cell phones.
02/16/2009 12:36 PM
To connect your lap top while driving, simply open the driver's side window, set the laptop on the driver's side miror, and make a sharp right turn. Connection problem solved.....
02/15/2009 11:42 AM
After forgetting to turn Caps Lock off, but pressing the shift key in the appropriate places, you may end up with eg:
tOGGLE cASE
If you now change to Sentence case, you get:
Toggle case
... while what you really wanted was:
Toggle Case
The Engineer
Good Answers: 129
02/15/2009 6:50 PM
In that case you shouldn't select "sentence case", you should select "Title Case" and it will give you the desired result.
02/15/2009 7:18 PM
Title Case just converts to lower case with initial caps - it doesn't work if you entered:
tOGGLE THE cASE
... but wanted:
Toggle the Case
... coz you get:
Toggle The Case
Q.E.D.
The Engineer
Good Answers: 129
02/15/2009 9:17 PM
Yes your right JohnDG, it can't read your mind. Well done.
Good Answers: 68
02/16/2009 3:16 AM
Hello JohnDG,
I have given you a GA also. Both ways to do alterations save time, thank you! And, it always seems to happen when you are busy and perhaps are about to leave the computer to go out. And you have to type like mad to replace your, or should I say 'my' cock up!
Take care
Good Answers: 68
02/16/2009 3:11 AM
hELLO rOGER,
I mean, hello Roger,
Can I thank you from the bottom of my heart for that advice!!!!!!!!
How much work is that going to save !
Thank Roger and you have another GA.
Which will mean diddle squat as you have three on this post so I will add one to the second explanatory post to give you two separate GA!...........Hope that makes sense. There isn't a 'make sense' button is there?
Take care.............
Good Answers: 68
02/16/2009 3:20 AM
Hello LL,
Thank you for screwing up!
I typed half a page in word the other daybefore realising it was in upper case, and (as I thought) had to retype. So thank you! Simple when you know how isn't it? Certainly gona save me loads of time!
Take care.
02/16/2009 12:07 PM
Hi bb,
Glad to help out. I screw up a lot. It sure is nice to have all these brains around who are willing to help us screw ups!
Thanks ALL.
LL
02/16/2009 4:15 AM
In MS Word (at least the version I have) holding the shift key down while pressing F3 cycles though : HELLO WORLD hello world Hello World
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Piping Design Engineering - Member United Kingdom - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
02/16/2009 4:57 AM
That is great. It's going to save even more time.
Have a GA.
The Engineer
Good Answers: 129
02/16/2009 9:33 AM
Pretty cool, thanks.
02/16/2009 12:47 PM
Hi , I would like to recommend this new utility that will assist you when you mix up between languages.
You can download and use LangOver for FREE here: http://www.LangOver.com For converting upper to lower cases just hilight the text and click shift+f7.
02/16/2009 5:36 PM
Easiest way is to press shift+F3 over the word
Ricardo Perry
Good Answers: 68
02/16/2009 10:20 PM
Hello Guest,
Your way fine as well................a GA to you!
Hobbies - Musician - Tube Amps Only Please!
10/28/2009 11:27 PM
If you are a programmer you can write a C or C++ program to do that very easy.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Register to Reply 19 comments
Anonymous Poster (3); babybear (4); Bayes (5); JohnDG (2); Kev_brown (1); lyn (2); maveric_manic (1); pswengineer (1)
