Previous in Forum: Spherical tank, help please.. Thanx   Next in Forum: pLUG vALVE
Hydro Power Turbine - Driveshaft Diameter
02/16/2009 10:20 PM
Dear fellow engineers,
I'm working on the design of a gravitational vortex hydro power.
Since there are very low RPM I have to deal with a very big torque.
In a 45KW application I will have 5400nm torque at the drive shaft.
How can I calculate the required steel thickness for the vertical drive shaft of the turbine?
I will probably be using 304 stainless steel pipe or solid. Any suggestions?
Thanks so much in advance.
Fred
Indonesia
Re: how to determine hydro power turbine driveshaft diameter
02/17/2009 5:46 AM
Hello,
why you do'nt use CAD-calculator? Please send me additional information such as threads, planned supports (distances) and keyway's, min. inside shaft hole etc., I try calculate. Contact oja.eng@mail.ee
P.OJA
02/18/2009 8:58 PM
Hi,
I downloaded the CAD-calculator last night. Great tool!!!
thanks so much for this advice, it's exactly what I needed.
Register to Reply 2 comments
