Previous in Forum: Hydro Power Turbine - Driveshaft Diameter   Next in Forum: Differences of 304 SS, 310 SS,.....321SS etc.
pLUG vALVE
02/17/2009 3:02 AM
WHY WE USE PLUG VALVE IN SULFUR JACKETED LINES?
Good Answers: 103
Re: pLUG vALVE
02/17/2009 6:05 AM
BECAUSE YOU WANT IT TO.
Re: pLUG vALVE
02/19/2009 4:07 AM
Mr. Sb also this is not a polit answer. If you dont have any information (this is what i think, cause u r electrical man not mechanical) please no need to replay the guests questions in mechnical section.
the choice of valves according to the system you have (during design stage), If you have valve selection hand book you will get all the information you need.
(types, classification, material, and where to use... etc)
I can give you a soft copy if u want.
regards
Re: pLUG vALVE
04/27/2009 6:38 AM
Halo
Can you provide me the soft copy of control Valve selection guide. My email: rony.dubai1@gmail.com
Thanks in Adnvance
Good Answers: 61
Re: pLUG vALVE
04/27/2009 12:39 PM
You have not given us enough information with which to formulate an answer to your question.
Be that as it may, let's first talk about some of the basics of Sulfur piping.
A. Sulfur is a "slurry". It will "Set-up" (get hard) if it has no flow and no heat input such as heat tracing.
B. You indicate that "jacketed piping" is involved. So you most likely have steam or some other hot fluid in the jacket and the sulfur in the center pipe.
C. You now want a valve that does not have "pockets" in it and one that can be traced or jacketed for heat input.
C. A Plug Valve can be traced or jacketed but is not a good valve to use for Sulfur because in the closed position it "traps" the fluid and could form a blockage of the pipe line
D. A "Diaphram Valve" would be a better valve for Sulfur. It does not trap the fluid and if you get one that can take the temperature can be traced or jacketed. http://www.asahi-america.com/diaphragm-Type-14-Flanged.htm
Do it once and do it right
Anonymous Poster (1); Naif (1); PennPiper (1); sb (1)
