Previous in Forum: Acid resistance butterfly valves   Next in Forum: White Layer in Nitriding
10 comments
Good Answers: 54
Poltergeist in a glass?
11/06/2006 2:17 AM
My 6 year old nephew and I were having snacks on our table which had a particularly smooth surface. His glass of cold softdrink was wet with condensation and the puddle had collected on the table. His eyes went wide open when, all of a sudden, the glass moved about four inches across the table without anyone touching it. He refused to touch it after that saying that it was possessed! I had a free drink out of it but was at a loss to explain what had happened.
Can anyone help?
Re: poltergeist in a glass?
11/06/2006 2:49 AM
Since I drink in bars frequently, I have seen this phenomena before. Think gravity and a super slick surface.
Beer. It's not just for breakfast anymore!
Good Answers: 54
11/06/2006 4:22 AM
I guess that's one explanation. I went the more complicated way and gave this explanation.
The glass has a curved underside, creating a pocket of air as the water pools around the glass. When the water reaches the depth where the air starts to push up the glass, the glass will float and magically slide along the surface until the surface either gets shallow or the air pocket leaks and the glass sinks back to the table top.
'Seemed logical at the time.
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
11/06/2006 5:00 AM
I think conditions come right for the glass to sit on a film of water that acts as a bearing. I've seen this myself, if you touch the glass, you can feel there is very little friction.
'The truth is out there' The lies are in your head.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member Hobbies - Musician - New Member
11/06/2006 8:11 AM
In addition, as the glass warms up, the pocket of air under the glass expands, lifting the glass enough to overcome the static coefficient of friction between the bottom of the glass and the water-slicked table.
"Blessed is the man who, having nothing to say, abstains from giving us wordy evidence of the fact." George Eliot [Mary Ann Evans] (1819-1880)
11/06/2006 8:42 AM
Yep, I could'nt agree more!
Re: Poltergeist in a glass?
11/07/2006 6:59 AM
Definitely the hover craft thing going on here.
Curved underside, trapped, expanding air and water providing the seal.
If you're not part of the solution, you're part of the precipitate...
Good Answers: 18
11/07/2006 1:06 PM
This sounds like...and would likely have made a good..."Challenge Question"
You have all the right pieces of the correct explanation here, by the way. Good post to think about. Too bad the condensate can't be resupplied down the glass at the rate that it is lost to the table, so it could keep going (at a speed below that which would entrain any of the air)!
Also, this happens more quickly when a drink has been taken, reducing the weight of the glass, and the glass is replaced onto an existing ring of water. As the glass is placed down vertically, it contacts the water at a raised elevation and traps more air than when it was first placed onto the dry table. The water seal allows the glass to compress a bit of the air, which produces a bit of upward force with which to start.
Call it 'half empty' or 'half full' if you must, I've got the other half in a redundant glass...
11/07/2006 2:40 PM
That's only true if the glass is set on a water ring, and not on pooled water.
11/07/2006 4:08 PM
Maybe not. If the underside of the glass is concave, it could still trap some air.
Good Answers: 54
11/08/2006 3:14 AM
You're right about the question being a challenge. I realize that now.
I often wondered if the pool of water had spread evenly around the table. Would the glass float around, sailing from port to port like it had a mind of its own? I think it would!
Register to Reply 10 comments
Anonymous Poster (2); merkelerk (1); mikey (2); PlbMak (2); Sandman (1); Vulcan (2)
