Previous in Forum: Wanted: One-Step Glue or Adhesive for ABS   Next in Forum: Solenoid valve for filling nozzle (gun)
8 comments
Vessels, Hydrotest Pressure and Design Pressure
02/20/2009 11:43 AM
why/how does a pressure vessel (designed for design pressure) withstand hydrotest pressure more than the design pressure? ( according to ASME SECTION VIII-2, ED 2004, test pressure = 1.25 X Design pressure X ratio of stress intensity at test temp to stress temp at design temp.)
Paresh B. Gujarati
Re: why/how does vessel withstand Hydrotest pressure greater than design pressure?
02/20/2009 12:05 PM
Because the allowable stress in design is lower than the yield/tensile according to the allowable stress basis.
(and why are you still referencing an old edition of ASME VIII Div 2 and not the completely rewritten 2007 (2008a Addenda)?)
02/20/2009 11:20 PM
Kinda new to the business of engineering, are you?
Many of us have worked on plants and equipment that are repaired, modified, expanded, inspected, and tested under the design code in use during initial construction.
Actually in some cases work done under a later code year would be considered uninsurable, unless every piece in the plant was brought up to the current code year.
It would be a nightmare for both owners and insuring bodies of these pressure vessels to even consider this scenario.
Good Answers: 51
02/21/2009 12:31 AM
Fair enough.
No.
I have just gotten impatient with the incessant questions regarding a project paper, and which I believe is a hypothetical design; where I don't see the value in writing a paper on a design that will be obsolete in a couple months.
Perhaps I was a little terse and/or assumed wrongly.
In either case, (rhetorical question to self) why even bother replying to something that frustrates me?
A little knowledge is a dangerous thing.
02/21/2009 9:30 AM
I am guessing that you replied as guest and that made me think you were more college attendee than a skilled professional.
So, hats off to you, but sometimes even us greybeards need to ask a simple question also.
Good Answers: 51
02/21/2009 1:51 PM
Yeah, I bounce around between a fair number of computers, and fail/neglect/forget to log-in sometimes. I think it causes a bit of confusion - I should really be more attentive.
Cheers.
Good Answers: 101
02/20/2009 12:33 PM
Safety factor.
Re: Vessels, Hydrotest Pressure and Design Pressure
02/21/2009 5:37 AM
For this reason, in any design calculations, the design code states checking of the stresses at many situations of loadings and/or combined loadings. And hydrotest is one situation which is essential to check the stresses at many locations of vessel, especially at mid-span and at saddles, and in no way the calculated stresses to be more than the allowed by the code.
Hobbies - DIY Welding - pipewelder
Re: Vessels, Hydro test Pressure and Design Pressure
02/23/2009 10:23 AM
On new vessels and large alterations only would I do a 1.5 hydro test. On repairs it is left up to the A.I. in charge but most will never require a 1.5 test pressure or on the other hand require less pressure than operating pressure for the test. We use to have 3 very old power boilers where I work that seemed to blow generating and super heat tubes routinely . We always did an 850 hydro test after we plugged a leaking tube until we got a new boiler superintendent and he insisted that we hydro at 1-1/2 times operating pressure. His idea was that we would find weak spots and eliminate bad tubes before they failed and he really did think that a 1.5 hydro pressure was required by the NBIC. If you ever met this guy would could see why he thought this. All he knew was what he learned (or was told) way back and was hard headed enough that no one could make him believe different. Not even the authorized inspector could change his mind on this. For about a year when we would repair these old boilers we would put the 1.5 pressure hydro test on them and then we would proceed to chase leaks for sometimes days before we would get a "dry" hydro test. It didn't take long before we had reduced the capacity of the boilers significantly. Finally the upper management realized that he had ruined the old boilers and decided to retire them after they fired the old man. My point here is that although a 1.5 hydro test pressure is required on new vessels/boilers and on some alterations one should use common since on older vessels/boilers that have lost some of their "safety factor" over the years. Ultimately it should be up to the AI to decide what the test pressure should be and most will take the age of the vessel into consideration but under no circumstances should you test a vessel/boiler at less than normal operating pressure. IMO
pipewelder
Register to Reply 8 comments
Abdel Halim Galala (1); Anonymous Poster (1); pipewelder (1); qaqcpipeman (2); RVZ717 (1); XMech (2)
