Previous in Forum: Stripping Cured UV Coatings from Plastic Parts   Next in Forum: Vessels, Hydrotest Pressure and Design Pressure
17 comments
Wanted: One-Step Glue or Adhesive for ABS
02/19/2009 10:45 PM
We are looking for a fast and hopefully one step glue/adhiesive for ABS.
Suggestions?
Pathfinder Tags: ABS Glue
Re: ABS Glue
02/19/2009 10:47 PM
MEK
More details, better answer.
Re: ABS Glue
02/19/2009 10:59 PM
Yes I thought of that after I hit the send button.
I have ABS body shapes that is ohhh,, .125" and less in thickness, that has sometimes good fit together nice and tight, other times there are gaps, You do not see the gaps, but they are there, so a watery glue won't really do it.
Right now we are using a glue that has the properties like a silicone caulking gun body. and this works great for both the tight as well as the not so tight fits. but is terribly too long set time.
I'm looking for something that is faster. that may still have some gap fiilling properties.
Re: ABS Glue
02/19/2009 11:05 PM
Still not a lot to go on, but, maybe a hot melt glue gun? The glue should stick to a clean ABS surface.
Re: ABS Glue
02/19/2009 11:13 PM
Nope, Sorry but no go on that, Thanks tho for trying to help. but the gluing parts are larger that what you could do without the glue getting too cold before finally getting the parts together.
Think of body panels of a car in size, Like if you were to join a right quarter panel to the rest of a body type of situation. several feet of a seam.
Thanks
Re: ABS Glue
02/19/2009 11:43 PM
"Think of body panels of a car in size'
You think of it, I'm going to bed.
It's done every day.
Re: ABS Glue
02/20/2009 7:49 AM
I know it's done every day, we do it every day now, but we are looking for a better way than what we are using now.
It works yes,, but it is a two part process, and slow, we'd like it to be a single component if possible, and now have to wait overnight for it to set.
Thank you All.
Re: Wanted: One-Step Glue or Adhesive for ABS
02/21/2009 7:51 PM
Acetone. $15.49 USD/gallon at Lowes.
02/22/2009 9:36 AM
Are you ABS to itself, or another material?
02/22/2009 9:48 AM
To itself as well as to painted metal.
02/22/2009 10:16 AM
So, you are bonding to ABS and paint, which COMPLETLY changes everything.
Garbage in garbage out!
02/22/2009 10:32 AM
agreed. ABS will respond to acetone like model glue. Take a calculator or some other little plastic device and pur some on. See.
Now binding to painted metal - geez. Pliogrip tm is expensive but it will definitely do the trick.
02/22/2009 10:47 AM
If you don't ask a good question, you won't get a good answer.
Bonding ABS to itself is a completely different process that bonding ABS to paint, with a metal substrate.
It doesn't sound to me as if you have done much research.
Have you talked to your current material supplier?
How about a flexible, thixotropic cyanoacrylate, with a paint on initiator.
We still don't know how big the gaps to be filled are? My crystal ball is broken.
Good Answers: 93
02/22/2009 8:57 PM
I may or may not be able to contribute anything at all to this thread. However in general I would appreciate it if CR4 posters did not assume that all readers knew what their acronyms meant. ABS means to me Automatic Braking System. In the months prior to the War In Iraq I identified articles in the papers as propaganda plants by the number of acronyms, secret jargon in the writings. It is in my opinion polite at the least to at least once somewhere in the body of a piece, to use the entire phrase, for which the acronym was to become shorthand, or code. To me MEK is Methyl Ethel Ketone, and is an effective, but dangerous solvent. I can't really see it as a "one step" adhesive since I suspect to affect a bond it would require pressure to cause the solvent to allow molecular intermingling facilitated by it as a solvent. I am not ashamed at all to say this area is not one in which I am any expert. Sometimes I really do just read a thread to learn something, and feel it better that I keep my mouth shut. My point here and now is that it is common for posters to use acronyms, and of course they are warranted, but it would be nice if we did not assume that everyone either knew them, or that those of us from different disciplines who might not, had nothing to offer. I have marked this as off topic.
You don't get wise because you got old, you get old because you were wise.
02/23/2009 6:38 PM
Acrylonitrile butadiene styrene (ABS) (chemical formula (C8H8· C4H6·C3H3N)n) is a common thermoplastic
02/23/2009 8:50 AM
ACETONE.
02/23/2009 11:04 PM
I presume that you're in USA, so suggest contact DYMAX for some UV cure adhesives.
They can provide various gels that will "squish" into small places, yet still easily fill 0.25" gap. Can be repositioned until you make it set using heat, UV exposure or other means.
3M and DUPONT would also have materials. Just contact their applications help lines and they will jump over each other trying to help.
I know that DUPONT has a 2 part epoxy series with "mixing" nozzles fitting onto the dispensing tubes.
We can give you ideas, but ultimately the specialists will end up supplying it.
Fans of Old Computers - ZX-81 - New Member Popular Science - Cosmology - New Member United States - Member - New Member APIX Pilot Plant Design Project - Member - New Member
03/23/2009 10:52 PM
You mention bonding ABS to painted metal -
There are some pretty good two part structural adhesives that can be blended in various ways (work with the suppliers) that can come in small disposable dual side by side syringe assemblies with inline mixing tubes - small quantities all the way up to compressed air driven production capability etc.
Many of these have work times down in the 1-2 minute range and set up pretty strong in 10-15 minutes - (auto assembly industry comes to mind)
Also, you might want to make sure that the structural adhesive manufacturers are involved. They might encourage you to adhere ABS to powder coated metal (plastic to plastic bonding then) but then you need to work with the powder-coater to be sure that the powder-coating is adhered well enough to the metal - or you can rip it right off the metal. Why?
The biggest difficulty is that you're working with two materials that will creep at different rates (grow in differently in length or width; driven by temperature changes) and thus, the bond is likely to be in a state of tension or compression with every temperature change away from original bond state -
You may also want to consider an adhesive with a body of thickness that can stretch and compress a bit -
just my $.02
-- Jim Wilson
Register to Reply 17 comments
eagertask (1); Just an Engineer (1); lyn (7); NSS (4); TexasCharley (3); Transcendian (1)
