Previous in Forum: Inner Fire Engine   Next in Forum: Toyota Camry error PO420 exhaust sensor problems
fixing sensor
02/21/2009 3:14 AM
hi,
if it is possible to fix sensor,,,which sense the limit distance(the distance b/n the cars front moving car and rear coming car..by setting the accident prevent distance.....to the sensor ...sensing that distance and it should slowdown the speed of rearcar automatically....is this possible..why can't we do this.....
Re: fixing sensor
02/21/2009 12:55 PM
That is being developed right now, using radar technology.
Good Answers: 123
Re: fixing sensor
02/21/2009 11:44 PM
It will work well on a test bench right now, but when it is installed in a production car, if it should malfunction, the results could be fatal, and the law suit would be sure to follow.
Bob
Re: fixing sensor
02/22/2009 12:31 AM
This was my thought as well, way back when ABS on cars was new. But ABS has been successfully installed on almost all vehicles, with no lawsuits of which I am aware. I believe that the same approach will work here.
The collision avoidance system (CAS) will continuously self-test, and if it fails, a dashboard light will indicate failure status, and then it is on the driver. This is easier than ABS: with brakes, you had to ensure that the brakes failed safe (default to normal braking, not complete loss of brakes). Whereas with CAS there is no tie-in to a safety-critical system; it is extra information only.
