Previous in Forum: fixing sensor   Next in Forum: Peugeot 307 hdi Anti Pollution Fault
12 comments
Toyota Camry error PO420 exhaust sensor problems
02/21/2009 5:19 PM
I have a 2001 Toyota Camry with engine check error PO420, which pertains to the exhaust gas system. The exhaust manifold and catalytic converter was replaced less than a year ago. The front and rear Oxygen sensors were recently replaced when I started getting the error. The error code comes back after about a week of driving. If I eliminate the catalytic converter and the 2 oxygen sensors as potential causes of the error, what else is possibly causing the problem ?
Any help is welcome.
Tks in advance
Pathfinder Tags: engine check PO420 error
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
Re: Toyota Camry error PO420 exhaust sensor problems
02/21/2009 6:41 PM
These codes are usually just indicators that a problem exists but often not specific enough to go replacing parts without further diagnostics.
Was there only the one code? That would be unusual.
Some things to check would be 1) electrical connections to the oxygen sensors, 2)leaks at manifold gaskets, 3) proper air/fuel mixture (need an exhaust gas anylizer) 4) any other codes.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
02/22/2009 10:48 PM
Try cleaning the contacts on the intake "MAP" sensor (female and Male) and verify that
they are making good contact. Then check the O2 sensor contacts and clean those as
well. GL
02/23/2009 8:41 AM
Clean out the hose/tubing that goes to the sensor.
02/23/2009 7:22 PM
Code PO420 is a OBD 2 Generic Code which is not manufacturer specific and applies to all makes and models including imports .
The code PO420 is defined as ; Catalyst System Efficiency Below Threshold ( Bank 1)
I would check for leaks in the exhaust system including the manifold , bad connections on the Oxy. Sensors , leaking Oxy. Sensor threads, cracked or faulty Cat. Converter.
Sounds like one of the replacement parts you had installed is causing the grief.
Question : Why did you have to replace the manifold and Cat. Converter previously ?
What dosent kill you makes you stronger , lifes a trip so sit back and try to enjoy the nice scenery.
02/24/2009 11:21 AM
I had the front exhaust(integral Catalytic converter) system replaced by Speedy last fall 2008 .I went to Speedy because the parts and labour were about $500 cheaper than the parts alone from Toyota.. It took about 6 months before the PO420 error came up. I reset it and it would take about a week before it came back. The estimate from Toyota just to diagnose the problem was more expensive than the cost of the sensors I replaced (Bosch and NTK). The cost of original Toyota parts are too high (one sensor is more than the cost of both units I bought through NAPA).
I will take all the tips in mind and inspect things more closely.
Tks folks.
Good Answers: 123
02/24/2009 12:34 PM
Most parts sold by NAPA will meet or exceed OEM specifications.
Bob
11/05/2009 1:27 AM
man i hav the same problem except mine smokes every morning when i start it any help on that
02/23/2009 9:13 PM
After checking some of the other reply's make sure the sensors are getting power. They heat up electrically before the engine warms up.
http://www.alldata.com/ Buy a years subscription appx. $29.95 for a years service.
02/24/2009 6:02 AM
Check the gas cap. My wifes old Grand Am threw this code several times and it was always a loose gas cap. If it is loose it will take several "good" trips before the light goes out if you don't have a way to reset it.
Shawn
02/24/2009 10:42 AM
Hello
I can feel your pain as my wife has the same problem with her 2000 Camry. She also had her catalytic converter replaced after an accident several years ago. My feeling is that the replacement catalytic converter was an after market one and after so many miles it does not remove the contaminants, triggering the PO420.
I would ask the question, "Was original equipment used when replacing the cat"?
We have not found a course of action yet and are still searching for a solution other than replacing the whole cat.
Let me know how you make out.
Time and money.....we battle this constantly.
11/05/2009 8:33 AM
Hello
This is an update to the previous post and should help some people with the same problem. It wasn't the Cat!
This is usually a oxygen sensor and the Camry has 2 of them. If you get this code try removing the sensor and using a wire brush to remove the carbon scale build up. Clean 1 at a time and use a OBDII code reader to clear the code. If the same sensor comes back on replace it, if not clean the other and repeat process.
I also have a Volvo and cleaning the sensor and clearing the code, the error has not come back.
The sensors are also very easy to remove by unscrewing them using an adjustable wrench. Cut the wire ties leading up to them, because as you unscrew the sensor the wire will twist. If you don't cut the ties the wire could break under stress.
Good luck.
search engine optimization
08/10/2010 5:56 AM
Camry is very beautiful and powerful car but i do not know why it did not perform well in india.... Toyota is a very famous brand in india and Toyota,s innova is very famous in india......
http://www.ddipro.com
Register to Reply 12 comments
Anonymous Poster (4); bob c (1); Carpe Diem (1); Laserlover (1); machine head (1); poormanslexus (1); rhandwor (1); Shadetree (1); Shawn33 (1)
