Previous in Forum: HT Motor Repairs   Next in Forum: Fuse Ratings and Standards
United Kingdom - Member - British
12V Safety
02/23/2009 3:02 PM
Is there any danger of putting 12v through a 20v laptop, or 12 through a 14.4v drill?
bondy111
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: 12V Safety
02/23/2009 4:08 PM
What exactly do you mean by "danger" and "through". How do you "put 12V through a 20V laptop"?
Tom
Re: 12V Safety
02/23/2009 4:30 PM
What are voltage ranges over which the devices will work? If 12V is outside the range then the device won't work properly or at all.
Why do you want to know?
Re: 12V Safety
02/23/2009 6:44 PM
Yep. The worst thing it could do is not work. Much like plugging a 220VAC device in a 115VAC outlet.
Humm... suspicious you are...
Re: 12V Safety
02/23/2009 7:08 PM
Under voltages could cause some problems but likely will not. An exterme difference may cause too much heat and damage the insulation. But you are talking about very small differences.
The laptop may not turn on at low voltages, but the drill will work, just don't expect the output to be as strong.
We had a 120vac coil running on 24vdc for a few weeks and it onle lost some holding power, but no noticable damage.
CARPE CRUSTULORUM!
Re: 12V Safety
02/24/2009 3:49 AM
The laptop will not work or will not charge the battery. The drill will work on reduced RPM/power...
Aged man is not old man...
Re: 12V Safety
02/24/2009 10:48 AM
Thanks so there is no harm in trying... If I don't reply in the next few days, you will know what has happened...
bondy111
Re: 12V Safety
02/24/2009 12:52 PM
I can only say I simply would not do it. There is no known reason to try it, unless you are happy to risk having a damaged Laptop.......
Use only the correct voltages and polarities........
Register to Reply 7 comments
Andy Germany (1); bhrescobar (1); Bondy111 (1); jack of all trades (1); not so smart (1); Qqberci (1); tdesmit (1)
