Previous in Forum: Fish Chum Chopping Machine   Next in Forum: Maximum Velocity of the LM Rail
Malaysia - Member - Kimie
Chillers and Compressors
02/24/2009 1:09 AM
i got confused with istallation of air cooled chiller 2 horizontal screw compresors 5000kg (Dunham bush AFHX 115T).The chiller located on the slab(10ft x 16ft).The chiller unit come with spring isolator. But during my installation at site, i use rubber pad (3/8" thickness) instead of spring isolator. For each compressor consists of rubber pad already about 1/2"(from manufacturer). Is it acceptable during the unit is running? There are flexible joints for chilled water out & in.
Kimie
Re: Chillers and Compressors
02/25/2009 8:53 AM
USE GOOD MOUNTING PADS DESIGNED FOR YOUR COMPRESSER OR YOU WILL GET VIBRATION DAMAGE TO THE CYLINDER WALLS AND MABEY THROW A ROD OR BUST A CYLINDER HEAD LIFTANDLUBE.COM HAS THESE ITEMS AND FLOW DRYERS AS WELL
http://www.liftandlube.com/product_p/curt%20vpm-120gal.htm
GOOD PRICE ON EVERY THING THEY SELL
03/03/2009 3:36 AM
I have replaced the rubber pad with spring isolator. I hope my chiller will run smoothly during testing commissioning.Thanks for advise.
02/25/2009 10:59 AM
You better installed sprin isolators for the chiller and install a rubber pad between the leg of the chiller and the isolator, I suggest you log on to mason industries they are manufacturers and there is guidelines on the desgin of the isolators that depend on the distribution weight of the chiller and include seismic zone data
http://www.mason-ind.com/masonind/home/index.cfm
please let me know how it goes
Tu conoceras la Verdad y la Verdad te hará Libre......Jesus
03/03/2009 3:37 AM
03/03/2009 2:46 AM
Anonymous Poster (3); Frank-Jazz (1); Spotsart (1)
