Hi
Can anyone help me with the design of a simple fish chum chopping machine.
I would like this installed on a small boat where 12 Vdc is available and I could use auto starter motor suitably geared down to drive it.
Input would be in the form of fish scraps, small bait fish as well as larger pieces of fish waste including frames etc.
I need this chopped up (not minced) to about 1 inch (25mm) cubes max.
I have tried using a large meat mincer with 4 large holes in the plate instead of all the smaller ones but I still get mince output. I know how to make a screw drive so it is the chopping part that is the remaining challenge. Chopping into 1 inch strips is relatively easy but then getting these strips cut again into cubes in a single pass is the tricky part. Any ideas?
Thanks
Mike
