Previous in Forum: Cooling Tower Pump and Submergence Level   Next in Forum: Routing of Hot Drain Pipes
Air Conditioner Design
02/25/2009 3:33 AM
Dear Sirs,
I have to aircondition an room containing 9 no's Variable Frequency Drives(VFD) of area 1400 Sq.ft and height of 12 feet.
Please guide me to design an airconditioner for the above requirement with full explanation.
Re: Air Conditioner Design
02/26/2009 12:14 AM
my friend the airconditioning design is depend on amount of heat generation in your room.
There are so many factor to be consider for designing airconditioning
howmuch heating produce from your 9 variable frequency drives + how many heating equipment placed in that room+ how many wattage of light in that room+ how many glass window are in that room+ how many and how much area of wall facing hot sunlight+ which type of wall is that room constructed of+ etc...
02/26/2009 9:49 AM
Dear sir,
Heat produced by
9VFD'S = 1200 JOULES
LIGHT = 750 WATTS
GLASS WINDOW = 9 NO'S
65% OF THE ENTIRE AREA
PCC WALL CONSTRUCTION.
03/22/2009 3:47 AM
For A/C design normally we use rule of thumbs, just need to know what type of the room, its area and multiply with factor (the factor must be refered from design and cooling load check figures)
To calculate cooling capacity (Btu.hr) = area (sq.ft) X factor (Btu.hr /sq.ft)
Let say, room's area 1400sq.ft X 120( refered from design & cooling load check figures).
So u get 168000 Btu.hr
Register to Reply 3 comments
amiruddin (1); Anonymous Poster (1); srinivigna (1)
