I have to route verious Steam, condensate drains to flash tank. Flash tank outlet is connected with condenser, which is under vaccum. Can i drop drain pipes to put valve assembly at ground level and then go up to connect with flash tank. What is the criteria of pressure for making such kind of loops (i.e dropping down & coming up). Generally we connect the drains with continious slope towards flash tank.
But, At some places drain outlet from drip leg is at lower elevation than the flash tank nozzle connection. Please suggest.
