Previous in Forum: electrical   Next in Forum: Design of Relay settings
how can calc
02/25/2009 7:19 AM
HI
i need to know
how can i calc. trnasformer capacity 20kvto 400v
if i have FLA , RLA , and starting ampe
Re: how can calc
02/25/2009 9:37 AM
In the US, you need to use the FLA (full Load Amps) to size the transformer. It needs to be a minimum of 125% of the FLA of the largest motor, plus all the other motor FLAs added up. Then KVA is just Volts X Amps X square root of 3 for three phase circuits. Keep in mind, 125% is just for the US under the NEC. Other countries may have a different approach.
Joe the Electrical Contractor to the EOR, I know it was suppose to be in my base bid, but I still am going to submit a change order for it.
Re: how can calc
02/26/2009 5:06 AM
Thanks so much
Register to Reply 2 comments
