Previous in Forum: conveyor belt material   Next in Forum: Sampling Dangerous Materials
13 comments
Is This Plastic Vinyl?
02/26/2009 6:49 AM
I've installed vinyl siding on my new shed. I'm thinking about using some lengths of plastic angle, that I have on hand, for trim on the shed. I believe the plastic angle was intended for indoor use and I'm wondering if it would hold up in this outdoor application. Is there a simple way to determine if the plastic angle is vinyl? The angle is white in color.
Pathfinder Tags: vinyl siding
Re: Is this plastic vinyl?
02/26/2009 8:45 AM
If it's vinyl, acetone or MEK will dissolve it. If it's polyethylene or polypropylene, they won't.
Mike
02/26/2009 8:59 AM
acetone or MEK will also dissolve ABS, styrene and some others.
02/26/2009 9:17 AM
Right after I posted the above, I added what you just said almost word-for-word. I don't know where it went.
Mike
02/26/2009 11:26 AM
You know what they say about great minds.
02/26/2009 8:54 AM
In a word, no. Depending on the formulation, PVC can range from very rigid to very flexible.
My guess is that if it's extruded angle it could be ABS, PVC or polystyrene. Or any of a dozen others.
If there is no recycle symbol on it it's hard to say.
Long ago, we used the smell test to help determine the type of plastic we were dealing with. Carve off a hunk, set it on fire and smell the smoke.
Don't know if you can find information the test on Google, or not.
Go ahead and put it up. It'll last for awhile.
02/26/2009 8:54 AM
Find a thick piece of copper wire, heat it with a torch until it glows, hold it to the plastic in question and place the wire in the flame again.
PVC will produce a distinct green glow when burnt with copper.
Don't breath the fumes. Not pleasant.
I have found that honor lies in doing the right thing even if no one is watching. Dignity lies in letting others take the responsibility and character lies in being able to smile as you walk away.
Re: Is This Plastic Vinyl?
02/27/2009 4:22 AM
See if you can find someone with an infrared spectrometer (most chemistry labs have one), I use one all the time at work to identify differences polymers
Hobbies - Fishing - Zoomer
02/27/2009 9:27 AM
Even if is is vinyl, if it is meant for indoor use it may not have UV resistance and will break down after a few years in the sun. Vinyl siding, rain gutters, etc., have chemicals formulated within the plastic to resist UV rays. The UV rays of the sun are very unfriendly to many types of plastics. Unless you can paint it with a UV resistant paint, it may not last long.
-Dennis
When in doubt, do it the right way.
02/27/2009 9:45 AM
This has so little to do with your question... except that some of the same (possibly) components are involved... take a quantity of styrofoam (such as you'll find in a throwaway(?) coffee cup) & mix it with gasoline/petrol to make a terrific glue like material. Great if your out camping & need to patch a boat, etc. That's it for now. Carlos
"The choices you make might be mistakes but its never too late to turn around." Tony Lang- musician
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
02/27/2009 11:47 AM
FYI:
That happens to be the basis of a well known recipe (at least in the 70s) to make the gelled filling for Molotov cocktails...
Just my $0.02...
Good Answers: 68
02/27/2009 9:50 PM
Hello The JMAN:,
I thing there could be too much information in your reply................
Good Answers: 68
02/27/2009 10:02 PM
Hi vgsdvawt:
If this angle you have is flexible chances are it is vinyl. In case it is not. Try drilling holes where you intend to fix it rather than forcing the screw or nail through. As forcing a nail through will put stress into the plastic and the solar damage will make it crack very much quicker. Just a thought.............
If you drill it and it is fragile and possibly splits, is is likely not to be vinyl. Also from my experience, and I think I know the plastic angle you talk of, this will split. And I would advice to use a two inch or larger angle laid on top of a piped silicone sealant of some sort to prevent water intrusion.
Take care............................
03/02/2009 8:41 AM
Go to your local building supply store, buy an outdoor grade piece of trim for less than $1 a foot and put it up. I'm guess you don't want to have to redo the job next year or the year after if you put up a non-weatherable grade.
Register to Reply 13 comments
Anonymous Poster (2); babybear (2); Daddio926 (1); Lab Rat (1); lyn (3); Mikerho (2); The JMAN (1); Zoomer (1)
