Previous in Forum: Water Flow and Tank Pressure   Next in Forum: Hardening Gear Teeth
Hose Coupling Connector
02/27/2009 3:24 AM
Good day to you all,
One of our project require a washdown point for facade cleaning. It will be located at higher elevation (which someone needs a cherry picker to acces it). I want to conceal most of the pipe as much as possible. Is there a fitting that a hose can just be inserted and water will automatically flow in the hose without any valves? Probably like a ball inside a pipe, once pushed let water flow in it??
Re: Hose Coupling Connector
02/28/2009 5:39 AM
Do you mean a non spill quicke coupler?
Best regards,
02/28/2009 8:06 AM
Check out Hanson quick connectors, automatically close when disconnected.
Made from brass, S/ Steel high and low pressures. Should not be connected or disconnected under pressure.
03/02/2009 6:51 PM
many thanks guys...appreciate the inputs..
cheers
Register to Reply 3 comments
ericpolc (1); garth (1); Harmen Beskers (1)
