I've been repair a set of Integral Gears with Shaft. The shaft operation was in Low speed but High Force. I repaired by weleding on every single teeth using Plasma Transfer Arc Welding & the Filler Mat'l is was 410. Now the result of the Hardnes is was 60 on the teeth & 43 on the shaft. My Question is : " can we increasing the hardness ?" Note : rehardineng by nitriding. Thank's.
