he gents:
hope you can supply me with some info?
fisrt: what is the technical of using capacitors for example on single phase motors we use run capacitor connected with start winding, is that to make sine wave of the start winding opposite to that of for the run winding. i mean when its positive on the run the capacitor charge and when its negative on the run the capacitor discharge it on the start winding to make the rotor follows the magnet flux from start to run and from run to start, and why the start and run windings are different resistance? and what is the different between ac and dc capacitor?
will be greatful if some body has full explaining or the idea of single phase motors.
second: i have 100 micro farad dc capacitor 350vdc and its not marked for the polarity, will it work if i connect opposite way or i will hear the boom
sorry for this amount of questions and thanks for your help
