3ph AC input ---------rectifier---------inverter-------Variable Freq AC Output
you can use its reqtifier, but you must pay attention or do some modification to :
- Maksimal Capacity of the Rectifier ( if arround 25 KVA, then its enough for 25HP DC Motor)
- its microcontroller programming (if use PWM)
- to the range of rated output of the rectifier (motor DC controlled by changing the voltage, motor AC controlled by changing the frequency). is it equal/matching to rated output of motor.
- motor connection (is it supply given to armature or its excitation)
