Previous in Forum: Short circuit calculations   Next in Forum: Current carrying capacity of a conductor in AC & DC
multification factor for 3 ph Energy meter.
02/28/2009 2:45 AM
3 Ph Energy meter ration is 600/5.
But,C.T ratio is 200/5,
now,what is the M.F.for the same.
Pathfinder Tags: ....
Re: multification factor for 3 ph Energy meter.
02/28/2009 3:15 AM
Dear
The M.F is 3 for energy meter.
Mohan Kushwaha
02/28/2009 3:21 AM
Dear Mr.mohan,
Thank u, for the same.meanwhile let me konw the calculation plz.
V.Parthasarathi.
Good Answers: 103
02/28/2009 8:56 AM
I am not very clear about your question.
As I understand is your energy meter requires a 600/5A CT but you have put a 200/5A CT.
Hence the CT Ratio is 1/3rd and the meter will read (display) 3 times the energy consumed.
Expected mf = 600/5 = 120
Used CT is 200/5 = 40
assume there is a current of 600 A, in earlier case the current to the EM is 5A but with your CT it will be 600*5/200 = 15A
For the EM 15A current is equivalent to 1800A primary current and it will show the energy readings accordingly (though actual current is 600A).
but if the EM has already a CT inside the panel with 600/5 ratio and you have added another with 200/5 Ratio, then the EM reading will be 1/40th of actual
Good Answers: 244
02/28/2009 8:22 PM
If the meter has already a M.F, then the new M.F = meter M.F/3
If the meter doesn't have any M.F, then the M.F = 1/3
Hope it helps.
- MS
Register to Reply 4 comments
Anonymous Poster (1); msamad (1); Parthasarathi (1); sb (1)
You might be interested in: pH Electrodes, pH Transmitters, pH Instruments
