Previous in Forum: Fitting-to-Fitting Welding of Piping   Next in Forum: effective capacity of tank
Centrifugal Pump - Calculating Capacity and Head
03/01/2009 4:25 PM
please if i have impeller size .x.x.x in ,rpm ,hp ,volt ,hz and phase how to calculate approximate pump capacity and head
Try and fail better than fail to try
Re: centrifugal pump capacity
03/01/2009 4:27 PM
The best way is to not calculate and refer to the pump's operating curve available from the manufacturer.
Good Answers: 58
03/01/2009 7:50 PM
Not possible. You need to know a lot more about the geometry of the impeller before you can even vaguely start to calculate head and flow.
Register to Reply 2 comments
