Previous in Forum: Centrifugal Pump - Calculating Capacity and Head   Next in Forum: Spart Parts
effective capacity of tank
03/01/2009 10:20 PM
What is the efective capacity of a water tank ?
What are the data required for calculation & how to calculate it ?
Good Answers: 101
Re: effective capacity of tank
03/01/2009 10:41 PM
Volume of tank - volume of freeboard = effective volume of tank.
02/21/2025 6:14 AM
It's the volume between the lowest part of the overflow pipe and the highest part of the outlet pipe. It can be worked out from the mechanical general arrangement drawing of the tank and details of the connections, neither of which can be seen from here, and double-checked with suitable measuring devices such as a tape measure, dipstick, etc., which need to be sourced close to the tank's location.
