Previous in Forum: Motor Conversion   Next in Forum: power factor
electrical knowledge
03/02/2009 7:17 AM
what should be the trench dimensions in main electrical room
Re: electrical knowledge
03/02/2009 8:33 AM
It all depends on what you want to put in it? If it is for cabling what sizes and quantities? If there are going to be conduits, what sizes? You need to provide more information than that.
Joe the Electrical Contractor to the EOR, I know it was suppose to be in my base bid, but I still am going to submit a change order for it.
03/02/2009 10:22 AM
In addition to the above, it's got to be big enough for someone to get in and fix/service those cables while the duct is at design capacity.
03/02/2009 3:00 PM
guest; if your using oil filled transformers, it should be big enough to contain the oil in the room with out spilling into other areas. perry
Electron Plumber (1); perry (1); PWSlack (1)
You might be interested in: Trench Shoring Equipment, Electrical Connectors
