Previous in Forum: Hazard Analysis and Critical Control Point (HAACP)   Next in Forum: Abrasion Test on UV Coated Surface
window fitting
03/02/2009 11:00 AM
can i buy a pipe fitting that will tell me the exact o.d. of the pipe
Good Answers: 123
Re: window fitting
03/06/2009 11:08 PM
I have a caliper that I have trained to do just that.
Bob
Re: window fitting
03/07/2009 11:28 PM
The question makes no sense.
Why do you care about the OD of pipe?
Tubing is spec'd by OD, pipe by ID.
But if you want a fitting that will tell you the exact OD of the pipe, buy a female fitting.
The ID of this fitting will give you the OD of the pipe, sort of.
Garbage in, garbage in.
You should consider registering, and giving some details of the problem if you want a reasonable answer.
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
Re: window fitting
03/07/2009 11:46 PM
If you can't find your calipers, or you are working on a 3' gas pipeline, run a tape around the circumference and divide by pi
AussieBob (1); bob c (1); lyn (1)
