Previous in Forum: Thermocouple?   Next in Forum: What's the Difference Between HP and BHP?
earth connections
03/02/2009 2:24 PM
what is the main diffrence of the nutrl earth or normal earh connections plz tell me
5
Re: earth connections
03/02/2009 9:12 PM
MAIN difference: One is designed to carry current when the system is normal, the other is designed to carry current only when the system fails.
OTHER differences:
One is not always needed, the other is always needed.
One can be used to complete a circuit, the other must not be used to complete a circuit.
One is always insulated, the other can be bare.
They both run together at the same time with the hot conductors, but are not always the same size wire by code.
One can have more than one color code, one must be green or bare.
One is called an 'earthed conductor', the other is called an 'earthing conductor'.
One has a few specific details given in a code, the other has an entire chapter devoted to it in the code.
One is a fairly understood circuit component, the other can give rise to many problems and is little understood by many.
The list goes on.
Have fun getting to know the rest of the answers to this very important question, as this could be the difference between excellent work and dangerous work, understanding circuits or just drawing them, being able to troubleshoot or having trouble.
Please let us know what else you find to add to this list, so we may know if you get the understanding of the answer to your question.
Regards, CJM
I do not 'know it all', but i will admit that I would like to. CJM
Reply Good Answer (Score 5)
03/04/2009 9:15 AM
G.A.
But i think, whatever you have stated is the difference between neutral & earth cables. (not the neutral earth & normal earth) but very useful.
Thank you
03/04/2009 12:43 PM
You highlight a very good point Lspraba, in that terminology specific to region is critical to understanding the scope and meaning of a question or of an answer. This is the reason that I elected to use the word 'earth' rather than 'ground' for my response.
It is entirely possible that I missed the understanding of what his actual question was; that his wording was specific to a feature, such as the physical characteristics, the resistance value requirements, location, connection methods, physical contact area depth, dimension or moisture conditions etc.
It could be possible that regional differences, such as establishing two earthing points with different requirements, one for neutral and one for earthed connections. Perhaps he was making the distinction between dedicated neutrals for ground-fault or arc-fault circuits, and those connected to the earth bond point directly.
Of all the reference works I've seen, I don't think there is one that translates technical terminology between regions of the earth, but I can see it would have great value. CJM◊
04/15/2025 5:13 AM
CJMcGill (2); Lspraba (1); PWSlack (1)
