Previous in Forum: Abrasion Test on UV Coated Surface   Next in Forum: quality management
How Phosphorous Affects Steel
03/06/2009 2:59 AM
I Have tested the Structral angle IS 2062 for chemical & mechanical test. Material qualifies mechanical test, but fail in chemical only in phosphorous. The result observed are
As per standard req. is 0.045 +/- 0.005% as against this found 0.07%.
The application is subjected to corrosive atmosphere.
Can I get more input what will be the effect if I use the materal?
If I reject the material
Why should I reject the material?
Good Answers: 51
Re: How Phosphorous Affects Steel
03/06/2009 8:41 PM
The quick, easy answer is to reject the material and get new, however, this isn't always possible:
The additional phosphorous might add increased atmospheric corrosion resistance, however, it may be more prone to stress corrosion cracking because of the increased hardness.
In general phosphorous adds strength, but reduces ductility / makes the steel more brittle; in amounts less than 0.30% it has little effect on the weldability of low-carbon steel.
In your case, I would be cautious of the ductility/brittleness and definitely the Nil Ductility Tranformation temperature. Did you perform any impact testing? What will this steel be used for? At what lowest temperature?
A little knowledge is a dangerous thing.
Good Answers: 19
03/06/2009 11:19 PM
One thing about high phosphorous (and sulphur) is that it makes the galvanisation thicker and looks like orange peel.
omw7
Good Answers: 243
03/06/2009 11:20 PM
You will be liable for failure to use specified material. Lawsuit damages. loss of license.
If I reject the material.
Your project will be delayed and you will have properly held your suppliers accountable to the purchase order requirements and standard.
Because it does not meet the requirement s as specified.
Because you do not want to be comlicit.
Because if the material was shipped as compliant when the chemistry is out of spec, who knows what other parameters may be out of spec.
milo
03/06/2009 11:57 PM
Hi...you must specify application with such questions.
IS 2062 is just general purpose structural steel. Incase your application is for handrails, fences etc this issue really does not matter.
Anil Tiwari / Delhi
03/07/2009 2:58 AM
Yes, IS 2062 is generaly used for non pressure parts / non-code equipments / structural purposes.
If it is so, you can inform the client and use it. Nothing wrong in it.
The problem will be, most of the clients are not technicaly knowledgeable enough to appreciate this matter and accept the deviation !
K.Periasamy
03/07/2009 4:27 AM
General purpose steel procured from market is usually manufactured by rolling mills using billets made out of scrap steel.There is no really control on chemistry.The material is sold at lower price then the prime steel manufactured by major steel plants.It serves the purpose in general use with slight over design.
It is not be used for critical design or purpose.
Good Answers: 58
03/07/2009 8:25 AM
Phosphorous can lead to corrosion problems, especially if welding or brazing are involved. The end use and environment should dictate the acceptability of increased phosphorous.
Register to Reply 7 comments
Anonymous Poster (3); Milo (1); omw7 (1); welderman (1); XMech (1)
