Previous in Forum: Material Properties of Rubber Bands   Next in Forum: Designing of Vacuum chamber
How to calculate optimum thickness and coverage area?
03/07/2009 2:00 AM
Hello, i wanna ask is there any specific or rough ideas on how to calculate for the optimum thickness and coverage area for a given fluid for coating onto a surface, with a given viscosity?
Re: How to calculate optimum thickness and coverage area?
03/08/2009 4:03 AM
hello, dear colleague try with calcute the weight of the specimen before and after formation of the coating
03/08/2009 4:14 AM
Do you mean by measuring the wet film coating thickness (WFT, in microns) and the dry film coating thickness(DFT, in microns)? That would obtain the solid volume ratio % (SV%) by using
[(DFT/WFT)*100%].
From that, i could get the theoretical spread rate(m^2/litre) at that particular DFT by using
[(SV%/DFT)*10]
If the aboves are workable, can i subject the DFT to secondary test such as thermal and physical test?
Regards,
03/09/2009 1:50 PM
Is your goal to "subject the DFT to secondary test such as thermal and physical test?"
Or, is your goal to determine how much solution to apply to a surface to meet specification thickness?
03/10/2009 9:19 AM
Hi there, thanks for your reply.
My aim is to find out the theoretical coverage area that this certain amount of "coating solution" can cover. And i need to know how to find the optimum thickness for this coating solution.
Thanks!
Regards,
05/15/2009 4:55 AM
The surface force is needed for determining the theoretical coverage. How well the fluid spread across the surface depends on the interfacial force between them.
RadiumD-
Anonymous Poster (1); lyn (1); RadiumD (1); unaimed (2)
