Previous in Forum: Materials of Construction for Sulphuric Acid Tank   Next in Forum: How to calculate optimum thickness and coverage area?
Material Properties of Rubber Bands
03/06/2009 11:23 AM
I am looking for the material properties of normal rubber band in term of isotropic property data, weight and mass and general data (i.e. Modulus of elasticity E, Poisson's ratio U, Coefficient of thermal expansion A, Weight per unit volume of the wood and Normalweight f''c). Could anyone help?
Good Answers: 101
Re: Material properties of normal rubber band
03/06/2009 12:20 PM
Define Normal.
For material data try: www.matweb.com
Re: Material Properties of Rubber Bands
03/06/2009 4:09 PM
I would try a rubber band web site. The manufacturer should be able to provide this.
Register to Reply 2 comments
