Previous in Forum: Altitude measurement with GPS   Next in Forum: Anaerobic Digestion of Biowaste
density measurement
11/09/2006 12:52 AM
Can I have suggestions on slurry density measurement instruments that do not involve radioactive material. I am involved in cement based slurry density measurement and I need to migrate from radioactive based istruments.
Re: density measurement
11/09/2006 11:21 AM
density=mass/volume right....
So pass ur slurry through a vessel which could hold 1 litre of slurry measure the mass at that point..
I hope this should work...
Prasanna
11/10/2006 3:20 AM
Please check possibility using the Coriolis mass flowmeter.
Manufacturers: Emerson, Foxboro, Endress+Hauser, Krohne, etc.
VP
11/10/2006 5:55 AM
I believe there are some acoustic methods available that are robust enough for aggregates. But you'd need to investigate if any of them have developed far enough for your application.
11/10/2006 11:27 AM
For inline slurry applications the Corioliss device is probably the best I have used. I do not understand why you need a different intrument for nonradioactive materials. The real technical problem is the fact that the material is a slurry (radioactive or not). Slurries present all kinds of problems ranging from complex rheological issues to more expected issues like deposition, abrasion and plugging.
11/10/2006 5:27 PM
Google for a DENSITROL unit.If still available, they take a sample of the mix continuously and provide an output, either analog or digital.May or may not be compatible with your needs but worth a try..
11/13/2006 9:38 AM
Try out the Mobrey densitometer from Emerson (ex Micro Motion).
11/13/2006 10:33 PM
I imagine the slury is flowing and is being discharged into some sort of container or a moving conveyer system. Now if it is possible to arrange for the discharge end to be a horizontal "T" rotated at constant speed by a motor------like a lawn sprinkler in reverse; then the torque required to spin the T is a good measure of the mass flow rate.
Register to Reply 7 comments
Anonymous Poster (5); HiTekRedNek (1); Yanthram (1)
