Previous in Forum: plug setting multiplier   Next in Forum: carrier direct trip
4 pole generator
03/07/2009 1:29 PM
what are the advantages / disadvantages in terms of protection, stability and economic consideratin if a 4 pole generator is coupled with a Gas turbine (5100 rpm) through a load gera box?
Pathfinder Tags: 4 pole gas turbine generator
Re: 4 pole generator
03/07/2009 2:00 PM
comparing to what?
03/08/2009 10:16 AM
This may be too simplistic, the gas turbine speed of 5100 RPM will not work as a direct drive. The four pole generator on a 60 hertz system rotates at 1800 RPM, if it were 6 pole it would operate at 1200 RPM, 2 poles 3600 RPM ad nauseam.
The economics involved would involve the total design from mechanism diameters, forces, initial cost, maintenance expectations, materials etc.
If you fail to follow through, you will fail.
Good Answers: 247
03/08/2009 1:18 PM
You can't connect directly and get a useful frequency, so you must use a gearbox (or chain drive, belt drive, etc.). It is unclear what you are trying to compare. Gas turbine vs diesel? Direct drive vs reduction drive?
Register to Reply 3 comments
Anonymous Poster (1); Blink (1); otha (1)
