Previous in Forum: vertical clearance   Next in Forum: Solder degradation with temperature
Water Transducer
11/09/2006 10:30 AM
Hi.I'm a student of Elecrical & Electronic Engg. I want to make a pump control ckt by which the water pump will be operated automitically. I want to use Triac as control element but I become stack at the tranducer part which will trigger the triacs. Can you help me. If u have any batter idea u can also suggest me. please help me. i want to do some job which relates my study.thank you.
Anik
Student-EEE
Islamis University of Technology(IUT)
Dhaka,Bangladesh
Good Answers: 75
Re: Water Transducer
11/10/2006 6:47 AM
What about the water do you wish to measure? You could measure flow rate, pressure, level etc. and the type of sensor depends on what you wish to measure. For example you may have a float switch that turns the pump on when the water reaches a particular level. You could also do the same with a pressure sensor operating the pump when a specific pressure that is associated with a level is reached. It all depends on what you want the system to do and if you intend to buy an off the shelf sensor or build one yourself. If you can give me some more details I may be able to help.
Reply to Forum Thread
