Previous in Forum: Screw Conveyors vs. Spring Conveyors   Next in Forum: How to Select Vibration Measurement Equipment
How to Calculate Chain Inertia
03/12/2009 3:20 PM
I am trying to calculate the needed motor starting torque to drive a load similar to what is shown in this sketch, using the product of component Inertia and Angular Acceleration (Torque = Inertia X Acceleration). All mass properties and dimesions are known, but I don't know how to account for the chain mass in the inertia calculation.
BTW, there is no gear reduction - ratio = 1:1.
Thanks for any tips.
Pathfinder Tags: Chain moment of inertia
Good Answers: 183
Re: How to Calculate Chain Inertia
03/12/2009 4:21 PM
You can assume that the full chain mass is concentrated at the motor pinion radius since there is a stiff connection between them. So that the inertia will be I= m*L*R^2 where
m = mass per unit length of chain in kg/m (metric units)
L= Chain length in m
R= Gear radius in m Result will be in kg*m^2 as it should be.
Any other unit system can be used.
03/12/2009 5:26 PM
Seems like a great (and easy) solution , I'll give it a try. Thank you.
Good Answers: 247
03/13/2009 10:43 AM
Another GA -- clear, concise, correct.
03/12/2009 10:56 PM
you know mass and linear accelaration of the chain......so you know the force.Force multiplied by the pinion radius is torque to drive the chain.
03/13/2009 10:59 AM
That only applies during start-up or shut-down.
On constant speed running the acceleration formula does not come into play.
I agree with the GA already given.
03/13/2009 11:19 AM
Either torque or Force comes into play only when accelerating (angular or linear).Otherwise you need to supply only frictional losses.
Inertia is resistance to acceleration.
03/13/2009 2:07 PM
Right you are, quite correct. I had overlooked the original need to calculate the starting torque.
I agree with your statement, of course.
Register to Reply 7 comments
abasile60 (1); Blink (1); Floram (2); jooka (2); nick name (1)
You might be interested in: Leaf Chain, Plastic and Metal Chain, Conveyor Chain
