Previous in Forum: Nozzle Load Analysis for Atmospheric Storage Tank   Next in Forum: The Right Ball Valves
single plane
03/13/2009 10:39 AM
Any body help me to tell about what is single plane balancing and what is two plane balancing of rotating mchine.
Good Answers: 53
Re: single plane
03/13/2009 11:25 AM
See the Cylinder below. This is unbalance at two point at both ends. And it need to be balanced at both ends for both the heavy spots.this is a two plane balancing.it can be done only dynamically.
Now lets imagine (I hope you can) its thickness is very low or in other words compress this to near zero thickness. Practically both the unbalances are on same plane and you can find out a single point to put counterweight for balancing. And thats a single plane balancing.you can do its statically and dynamically.
Good Answers: 103
Re: single plane
03/13/2009 1:14 PM
Also check the earlier post on static and dynamic balancing (the static is as single plane balancing)
Re: single plane
12/13/2009 8:26 PM
rakesh_semwal, thanks for a tip BTW, did you guys checked this site www.oxygen.rs, it is promising.
Anonymous Poster (1); rakesh_semwal (1); sb (1)
