Previous in Forum: Thanks All For Window scratch repair replies   Next in Forum: Polymers and Specific Functional Groups
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Fire heaters : piping
03/16/2009 5:05 AM
Why do we prefer the equal flow at the inlet & outlet of Heater??
Atul singla
Pathfinder Tags: Fire heaters & Piping
Re: Fire heaters : piping
03/16/2009 5:22 AM
The Material Balance:
"Input = Output + Accumulation."
Good Answers: 61
03/16/2009 12:50 PM
It is not so much that you want equal flow but that you absolutely do not want to starve one of the tube passes.
You have fire inside that heater and the flame is "impinging" on the tubes. The fluid inside the tube carries away some of the heat by absorbing it as a part of the requirement of the process. If there was no flow in one of the tube passes then that set of tubes would get hotter and hotter and could fail causing a serious fire and possibly the death of one or more workers.
Do it once and do it right
Register to Reply 2 comments
