Previous in Forum: Drip Legs in Steam Lines   Next in Forum: Lawnmower Engine Can't Throttle on Choke
Tractor Design
03/16/2009 11:03 AM
Why do the front wheels of a tractor are always smaller than the back wheels?
siddhu
Re: Tractor Design
03/16/2009 11:24 AM
Because that's where the drive is.
Re: Tractor Design
03/16/2009 11:40 AM
That is usually the case with a 2-wheel drive tractor, but not a 4-wheel drive, because in a 2x4 () the larger fronts are more expensive, provide less visibility, more difficult to turn (especially in the early days of non-power assist), and can provide a tighter turning radius; conversely, the larger rear tires give better traction and also provides a "cheap" gear reduction.
Re: Tractor Design
03/18/2009 6:30 PM
I agree with everything you said except for the "cheap gear reduction" part. This is not true. The larger tires actually give the tractor a higher final drive speed since the circumference is larger.
In most cases the front tires are smaller when the tractor is 2wd. However, there are 4wd tractors with smaller front tires... these are sometimes called front wheel assist since they don't pull nearly the same amount as the rears. Once you get into the very large and powerful 4wd units, they virtually all have same sized tires in front and back for max pulling power. Often times they are in dual configurations or even triple!
Re: Tractor Design
09/06/2024 4:43 AM
It's got something to do with the steering track rod needing to pass under the engine rather than through it.
Register to Reply 4 comments
Anonymous Poster (1); bhankiii (1); PWSlack (1); stephent (1)
You might be interested in: Wheels, Filter Wheels, Contact Wheels
