Previous in Forum: baaraa   Next in Forum: Current Transformers for 400 kV System
Safety - ESD - Inspect all things, keep the good things safe! New Zealand - Member - PalmerstonNorth -hub of the Manawatu.
Allan Bradley MicroView Cat2707 MVP232
03/17/2009 12:45 AM
What configuration software is needed to program this little MicroView panel?
I got this panel from a mate and need it to be programmed so that it will display temperatures and settings being monitored by a micrologix 1200 Allan Bradley PLC.
How hard would it be to use the software if I can get any?
What pc would be needed, i.e. windows 95/98 or even older?
Any info will help,THANKS
Observe-Plan-Execute-Monitor-Control
Re: Allan Bradley MicroView Cat2707 MVP232
03/18/2009 7:57 AM
The software used for programming the Mciroview is 2707-NP2 from Allen bradley and is very intuitive to use. This software can be used with window XPprofessional, widiow2000, Windows95/98. The only catch is that it will from a DOS prompt command line. The user manual will help to understand the software package.
Good Luck.
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2707-um005_-en-p.pdf
03/18/2009 8:01 AM
hello
i think that you need to have 2707-NP -programming software for this micro view , aso cable DH485 cable -with PIC to use with PC.It supports MS-DOS not windows.
If possible , try to migrate in to Panel View Micro -2711 family .
I handled all the products 7 years ago.
03/18/2009 8:08 AM
i think you can use this 2707-NP programming software with Windows 95/98 /XP ..but it's MS-DOS based software
you need extra hardware like PIC ( 232 to D485 Converter) and cable to do modifications
Register to Reply 3 comments
Anonymous Poster (1); coyot1 (1); sivamugunthan (1)
