Previous in Forum: Load Rating and Cable Sizing   Next in Forum: MCCB Query
Lighthouse Effect with Small Fluorescent Bulbs and Neon Indicator Switches
03/18/2009 12:29 PM
I made the mistake of putting an inline switch which has a neon indicator that lights when powered but not when in the on position, in a standard lamp that I was given. The reason I used that switch was that it was bigger and therefore easier to wire up. I put in an incandescent bulb and had no problem.
Later I replaced the incandescent bulb with a small wattage fluorescent. It was only when I went into the darkened room later that I was aware of a slow flashing and realised it was coming from the bulb, obviously being slowly charged through the neon indicator and then discharging through the bulb.
I had occasion to change bulbs around and ended up with a higher wattage bulb in the standard lamp which now was flashing brightly in daylight when switched off, so the time has come to replace the switch.
duikerbok
Re: Lighthouse Effect with Small Fluorescent Bulbs and Neon Indicator Switches
03/18/2009 1:40 PM
and do you need help with selecting a switch? sorry, but i don't understand the question.
Good Answers: 103
03/18/2009 9:55 PM
Not a question. This is a discussion (see No ? mark on the heading area)
03/18/2009 7:30 PM
Thanks for the info.
If it were mine, I'd just break/unhook the neon indicator.
Any idea how much power was actually being consumed by this? I don't think you could measure it.
Cheers!
Register to Reply 3 comments
Anonymous Poster (1); lyn (1); sb (1)
