Previous in Forum: Converting Inches-H2O to Airspeed at Sea Level   Next in Forum: What's the Best Way to Dry Wood Chips Mechanically?
AW 68 Hydraulic Oil vs. Rando HD 68 Hydraulic Oil
03/19/2009 11:08 PM
Dear all,
What is the differant between AW 68 Hydraulic oil & Rando HD 68 Hydraulics oil. In my factory has a 150 Tons cpacity Hydraulic press machine. workig Pressure is 210 bar. My factory is located in Dominican Republic. I need to konw that what is the suitable Hydraulic oil for this machine.
Re: AW 68 Hydraulic Oil vs. Rando HD 68 Hydraulic Oil
03/21/2009 6:03 AM
Probably nothing try googling each product and compare ratings or contact manufactures of the products.
Better yet simply contact the makers of the Press and ask the manufacturer what they would recommend.
Sometimes I realise that is harder than it sounds if company is out of business . The AW and HD may denote detergent or other differences it should be easy to check or someone may help fro Cr4 .
Lighten up
03/21/2009 7:18 PM
I have been using any hydraulic oil with a "68" label and had used Rando HD 68, and or any brand labelled 68 in tropical countries. Shell telus 68 is the same or any other trusted/known hydraulic oil distributor. I cant go much deeper as to what are reasons behind this but it concerns with viscosity. Try gogle on oil viscocities. I am not sure whether it is a SUS(saybolt universal seconds).
