Previous in Forum: The National Energy Conundrum   Next in Forum: Savonius Rotor for Rooftop Windmill
Renewable Energy and Hydraulic Power
03/20/2009 8:50 AM
I have many years of research in the combinations of natural resources and have now put this innovative approch to this basic question, What if a power source is known that can power a steam power plant with a system of hydraulic pressure and storage tanks 4, tanks per hydraulic turbine that mantain the 2 stage pressure to drive the same generators that are in a steam plant from natural resources. Most people know that the biggest damange is done by the heat from the oils. This is needed to help maintaine the power output at night, ON DEMAND POWER.
Question 1. how to determine the PSI for 1 hose power ratio, Lets say the generators takes 80 horse power then what is the PSI storage required to mantaine the speed constant.
Renewable energy Researcher/Inventor
Re: Renewable Energy and Hydraulic Power
03/20/2009 4:11 PM
depends on tank size, a 1,000,000 liter tank at 1000 atm would do it.
03/21/2009 8:11 AM
What I was asking is let say the generator takes 40 horse power for constant rpms.
Then the psi required for this is what ? for 1 horse power tank size let say is 2000.gl
Heat produced is at 160 at base of cone shape which is 21000 ft what is the speed at the top where it is 80 ft. and 150 ft tall.
do you know what this is called ? here are some guess Vortex chamber, heat recycleing of the atmospheer, Natural wind ramjet. and many others.
CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Register to Reply 2 comments
