Previous in Forum: Tea Bag Machines   Next in Forum: NPT male thread pressure ratings
18 comments
Wind Tunnel Pressure Drop
03/20/2009 10:32 AM
I am currently designing a wind tunnel to test the pressure drop through a box with several slopes and turns. I will drill a hole on the inlet and outlet bottom of the wind tunnel, just outside the box, so that I can place a transversing pitot tube on both sides. I will measure the pressure distribution on both sides so that I can obtain an accurate solution to the pressure drop. I have tried Google, and I couldn't find an answer to this - how do I set-up the system of transducer(s), pitot tubes, Scope VI, etc. to measure this? Before, when taking data, I used to just use the system that was already in place. However, I am building one from scratch and do not have access to the previous system. If there is a website, you can direct me there. Thank you in advance for your response.
Good Answers: 53
Re: Wind Tunnel Pressure Drop
03/20/2009 10:53 AM
I guess you are from USA, AMCA 108 should be easily accessible to you.
go here
http://www.amca.org/
03/20/2009 11:13 AM
This is an interesting association; thanks. However, I am looking for an experimental set-up, not a standard. I want to know how I can hook up my pitot tube and transducer(s) (and any other equipment I might need) to obtain the readings on a computer.
03/20/2009 11:47 AM
OK, so the transducer will have some sort of output, and the computer will have some sort of input. They just need to be the same.
What's the transducer output, then?
03/20/2009 2:10 PM
It will be a voltage output.
03/20/2009 2:47 PM
this post is intentionally blank
03/20/2009 2:49 PM
My point being that my output is voltage - a response to a previous question.
03/20/2009 2:50 PM
Yeah, I know..I miss-read the posts,, I am just a cat.. my bad....and hence the hasty edit
03/20/2009 2:54 PM
lol. I see the traces of nut.
Good Answers: 101
03/20/2009 11:51 AM
03/20/2009 2:13 PM
Thank you. However, I am looking into connecting the wind tunnel - I already have it made. I just need to work on electrical.
03/20/2009 1:44 PM
With two monitoring points just connect them to eitherside of a differential pressure transducer.
Something like this push on pvc tube will probably suffice at the pressures you are likely to encounter.
03/20/2009 2:17 PM
Interesting. This would be a lot easier than switching between pitot tube ports. Now, I can essentially take the measurements at the same time, and find the pressure difference. I will only be dealing with about 5 in. H20, so this could definitely work
04/02/2009 2:47 PM
hey nathaniel, i am also working on a wind tunnel. what university are you attending? i am also in houston, tx.
04/06/2009 10:40 AM
University of Houston. You?
04/30/2009 12:43 PM
here at UH as well. we are designing and constructing a 15"X15"X24" wind tunnel. total about 12 ft in length. Need some help calculating the theoretical pressure drop at the entrance cone, test section and diffuser. Wind speed up to 60 mph.
04/30/2009 1:33 PM
Really at UH? Interesting. That's some good wind speed. Wish I could've used your fan for the experiment. Where are you set-up?
Anyway, we didn't do any theoretical calculations, so I am a little unsure of how to do that. If you gave me dimensions of entrance cone, test section, diffuser, etc. I might be able to help you out. If the test section is some weird geometry (i.e. box full of weird slots and dimensions), then that is really out of my scope and expertise. That would require a computational program that could only be determined with experimental data.
05/01/2009 11:17 PM
Yeah, here at the technology college. We are designing and building a wind tunnel for the fluids lab over the summer. I was trying to use Burnelli's equation of conservation but it gave me this weird pressure drop in the test section. test section: 15"hx15"wx24" l Contraction cone: 45"x45" inlet 15"x15" outlet, length - 30" diffuser: 5 degree angle, 30" diameter outlet, 15x15" inlet, 84" length. The test section is considered simple as of now, until we test for % turbelance we might add some slots of sorts to straighten the flow if we need too, but not for the calculations. what was your tunnel like?
05/05/2009 9:34 AM
Your wind tunnel definitely has a lot more ingenuity than ours. We just built two 2'x2'x4' sections that sandwiched a lateral flow reactor (just a fancy filter). We used PVC pipes at inlet to get rid of flow separation in the entry. If you want, you can email me your calculations and I could check them out to see if I catch any mistakes. It always helps to have another set of eyes. nathaniel.jolliff@gmail.com
I am not the best expert, but it seems you have enough tunnel length for the flow to be straight. What is the wind speed?
Register to Reply 18 comments
Anonymous Poster (3); DVader1000 (1); nathaniel1105 (9); PWSlack (1); rakesh_semwal (1); user-deleted-1105 (3)
You might be interested in: Wind Tunnel Testing Services, Tunnel Diodes
