Previous in Forum: Bearings clearances limits   Next in Forum: Cable Test
LED
03/22/2009 1:47 AM
Hi wheather the LED can be used as a zener diode
Good Answers: 53
Re: LED
03/22/2009 5:21 AM
Yes if someone has an LED that offers temporary reverse breakdown.
Good Answers: 54
Re: LED
03/22/2009 5:26 AM
Back when I was still in school, my instructor said that, yes, any diode (I guess that includes LEDs) will work as a zener except that zeners will regulate the voltage better than an ordinary diode. A zener has a sharper knee (is that the correct term? It's been a long time) than the standard diode.
Besides, not all LEDs are created equal. They will exhibit different breakdown voltages so if you damage one, you'll have difficulty finding one that exactly matches the old one.
However, I fail to understand why you would want to use a nice LED, whose purpose is to give off light when forward biased, and use it as a zener which it was not designed for and will not work as well as a zener.
Unless you're just curious, so that's okay.
This is not difficult to try. Just get an LED, a resistor, a power supply and a multimeter.
regards,
Vulcan
Re: LED
03/29/2009 11:53 PM
NO.! The forward voltage drop of a diode is 0.7 V. A diode is used to prevent reverse current. A LED is a special diode which will emit light in a specific frequency . (read colour) the LED needs to be current limited in almost all applications to about 20 ma. use the V= I X R relationaship to establish resistor values. do not forget that AC voltage numbers are RMS values (Multiply by 1.414 for peak AC voltage) If you use RMS the diode will probably burn out. I have used LED's as power "on" indicators for voltages up to 600 V AC. apparently the diode does not like this but it worked fine!
Bin there, done that, then done that again and again and now I forgot where I was.Is this what it means to get old?
Register to Reply 3 comments
MIKE L. (1); rakesh_semwal (1); Vulcan (1)
