Previous in Forum: cable testing   Next in Forum: Which motors require stator RTDs?
40 MVA 132/22kV Substations
03/22/2009 9:56 AM
Approximately, how many Secondary 2MVA 22/0.415 kV substations can be connected to a 40 MVA 132/22 kV Primary Substations?
Good Answers: 140
Re: 40 MVA 132/22kV Substations
03/22/2009 10:04 AM
Without having load and demand information, this is an impossible question to answer and any answer is nothing more then a guess.
You need to design this system based on the load you need to provide for.
Register with this forum will you please.
03/22/2009 3:09 PM
Approximately 20.
Please note that this is a discussion forum, not a free engineering consultancy service. For a more detailed analysis and an answer that will suit your particular site, you MUST consult your local electrical engineering design or consultancy group for a real answer.
03/23/2009 12:53 AM
Dear Friend,
40MVA 132/22kV substation came up with definite analysis, demand and connected loads. Check the LV, which required 415V and below.
* Make LV load analysis based on LV demand and connected loads.
* From here, you can sum up all LV loads, then convert this to kVA or MVA
* Once you have this, divide this to 2MVA, whatever the result(s), then "YOU HAVE THE NUMBER OF 2MVA SECONDARY XFMR.
Eren
03/28/2009 6:25 AM
Since this is a hypothetical question, then not more than 20 secondary s- stations due to the power equation. However this is to be determined by potential drops owing to supplying close to load centres and conductor length/type as this leads to power losses.
cheers
Brooks Wamala (1); ereneduarte (1); jack of all trades (1); North of 60 (1)
