Previous in Forum: Diagramming Plant Costs   Next in Forum: How to Select a Compressor
13 comments
APIX Pilot Plant Design Project - Member - New Member Engineering Fields - Piping Design Engineering - New Member
Self-Anchored vs. Mechanically-Anchored Storage Tanks
03/23/2009 7:05 AM
Could anybody explain me in simple words on differentiation between self-anchored and mechanically anchored storage tanks?
Pathfinder Tags: storage tanks
Re: Difference between self anchored and mechanical anchored storage tanks
03/23/2009 9:28 AM
Mechanically-anchored tanks are held down with mechanical fasteners.
03/23/2009 10:00 AM
So what holds a self anchored unit down?
03/23/2009 10:26 AM
Gravity. Either that or the Earth sucks.
Good Answers: 51
03/23/2009 4:03 PM
GA!
(in locations and cases where the wind and/or seismic effects do not warrant anchor bolts, then yes - the tank just sits there)
A little knowledge is a dangerous thing.
03/23/2009 11:49 PM
Does you all mean that the self anchored storage tanks are not fastened by anchor bolts? Then what will happen during seismic loads & wind loads?
Good Answers: 51
03/24/2009 1:42 AM
That is correct - a self anchored storage tank has NO anchor bolts; nothing happens to it during seismic/winds loads because it has been determined that the overturning moments do not exceed the dead load resisting moment of the empty tank (the wind/seismic loads are low due to location and tank size/parameters).
03/24/2009 1:48 AM
But I am refering to API 650 11th Edition. Appendix E.6.2 and these explanation is not inline with the code. Would you please refer and clarify the same again.
Good Answers: 51
03/24/2009 2:08 AM
E.6.2.1
Resistance to the design overturning (ringwall) moment at the base of the shell may be provided by:
  • The weight of the tank shell, weight of roof reaction on shell Wrs, and by the weight of a portion of the tank contents adjacent to the shell for unanchored tanks.
  • Mechanical anchorage devices.
E.6.2.1.1
The tank is self-anchored providing the following conditions are met:
  1. The resisting force is adequate for tank stability (i.e., the anchorage ratio, J≤1.54).
  2. The maximum width of annulus for determining the resisting force is 3.5% of the tank diameter.
  3. The shell compression satisfies E.6.2.2.
  4. The required annulus plate thickness does not exceed the thickness of the bottom shell course.
  5. Piping flexibility requirements are satisfied.
E.6.2.1.2 Mechanically Anchored
The tank configuration is such that the self-anchored requirements can not be met, the tank must be anchored with devices such as anchor bolts or straps.................
Good Answers: 51
03/24/2009 2:21 AM
I hopefully didn't confuse you regarding my comments on the empty tank earlier - I was lazy and looking at an old edition (10th Addendum 2):
3.11.2 For an unanchored tank, the overturning moment
from wind pressure shall not exceed two-thirds of the deadload
resisting moment, excluding any tank contents, and shall be calculated as follows:
But have since smartened up and I am currently looking at the 11th - 2007 edition (2008 Addenda) seeing as how you are a "serious" questioner and actually have the code in front of you.
The design overturning moments have changed (much like everything else in this VERY DYNAMIC code).
03/24/2009 4:20 AM
And flooding? They become boats instead (been there, done it, etc.).
03/20/2023 6:53 AM
They will wobble in harmony.
03/23/2009 10:18 PM
You just "Earthed" him right in with that first answer, didn't you!
03/24/2009 4:21 AM
Register to Reply 13 comments
Anonymous Poster (1); Kilowatt0 (1); Kumaran (2); PWSlack (5); XMech (4)
