Previous in Forum: Dedicated Circuits for Analog Computing   Next in Forum: Array Electronics SR PLCs
Chlorine Sensors
03/23/2009 9:57 AM
Can anyone tell me how a closed loop chlorine measurement system works. What kind of signal does a chlorine sensor give? For instance I know that a thermocouple transduces temperature to mV. What happens with a chlorine sensor?
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
Re: Chlorine Sensors
03/23/2009 4:20 PM
Guest,
As far as I am aware, amperometric electrochemical sensors that measure chlorine gas concentrations also results in a linear output in the milliampere range.
(typical sensor output from 1 to 20 MA)
Just my $0.02...
03/23/2009 7:22 PM
Membrane-covered amperometric measuring cell
for free chlorine
Part Number:
20263040CUSTOM
Datasheet:
20.2630, pages 1-6
Membrane Type:
hydrophobic PTFEOR hydrophilic
(reduced pH dependence)
pH Range:
5.5 to 8OR4 to 12
pH Dependence:
- - -within range
5 to 7 pH
no loss of slope
Measurement Ranges:
(select below)
0.000—0.500 mg/l (ppm)
0.00—1.00 mg/l (ppm)
0.00—2.00 mg/l (ppm)
0.00—5.00 mg/l (ppm)
0.00—10.00 mg/l (ppm)
Power Supply:
12 - 30 V / DC
(isolation is recommended)
Output Signal:
4 - 20 mA, 2-wire
Incident Flow Velocity:
approx. 15cm/sec
Operating Temperature:
>0 to +45º C
Dimensions:
220 mm /
(length)
25mm
(diameter)
Applications:
aqueous solutions (e.g., drinking or pool water,
as well as service, process or cooling water)
10 seconds on google got me this
03/26/2009 12:53 PM
Check out sume instrument suppliers' websites. Endress + Hauser and Emerson Process (usual disclaimer on both) spring immediately to mind.
lyn (1); PWSlack (1); The JMAN (1)
