I got a crusher mill that is powered by one 90kW induction motor. The company suggested that I can use their spare 90kW motor in conjunction with the existing motor to upgrade the mill`s performance since it is under powered by about 60kW.
A method is to remove the existing 4belt pulley and fit an 8 belt pulley on it, then have the 2 motors on each side driving it with 4belts. The mechanics seems straight forward.
How do I start these two motors by means of soft starters? Any Ideas about the control circuit for this occation, and what about protection for different types of loading faults?
Can I use two soft starters to start two motors driving the same shaft or will the torque management of the one soft starter intervene with the same function on the other soft starter?
Can some GURU give me light on this please.
