Previous in Forum: Computerized Maintenance Management Systems (CMMS)   Next in Forum: Screw Conveyor Suppliers
Beams and columns
03/26/2009 1:42 AM
What is the difference between beams and columns?
Where they can be used?
Re: Beams and columns
03/26/2009 4:30 AM
A column is a vertical member and a beam is a horizontal one. The cross-sections will be different. There are textbooks on structural mechanics that detail the application of these cross-sections and to these must be the next step.
03/27/2009 2:53 AM
Thank you PWslack,
Can you give a practical example where columns and beams are used.What will happen if we use beam in place of column.What are the modes of failure for them.
Regards,
Dinakar
India
Register to Reply 2 comments
You might be interested in: Columns, GC Columns, Beams, Joists and Wall Studs
